Old 02-16-2014, 04:33 AM
Markus K. Markus K. is offline
Markus K. is on a distinguished road
Default Re: 1/10 Liebherr Excavator R 984 Litronic
Good morning,
today the first boom pictures. I choose the short one for the model. It measures from main bolt mounting to stick bolt mounting 780mm.
It's not only a foursided housing, there is some structure inside to stiffen the whole thing. As you can see, the drum inside is made with two halfs whitch were welded together. The outer diameter is 74mm.
