Old 02-21-2014, 03:04 PM
Default Re: Limit switch wiring help
The only connection between the main ESC ( drive for the truck) and the one for the box is main power supply from the battery. I soldered both power wires together and installed a battery style plug to fit the ones I use .
A terminal block is a better way to go to connect your electrical devices to main power supply... sure beats having to cut & resolder everything when one device sh!ts the bed.
http://www.thesource.ca/estore/Produ...FY1AMgodRFwADw
