Old 04-11-2014, 10:20 PM
Good point about the heat-sinking effect you get with vises and pliers holding the parts. I forgot to mention that I switched to paper-binder spring clips to hold things. They don't soak up much heat, are cheap, available in many sizes, and can be tossed when heat removes all the spring tension from them.
Good luck!
