Old 05-19-2014, 12:04 PM
540-MAN's Avatar
540-MAN 540-MAN is offline
540-MAN is on a distinguished road
Default Re: My new Knight Hauler/Freightliner
Originally Posted by mavrick0 View Post
Sounds as if you are overheating the ESC and it is going into thermal protection mode and shutting things down. Without the trailer there isn't the load on the ESC so there is no reason for it overheat. Not knowing what trailer you are running I'm going to assume it's probably heavier then the stock Tamiya trailer. One suggestion would be to change the pinion on the motor and drop it down a tooth or two or try going to a crawler motor that has more torque for pulling but not as fast as the stock motor.
This is the trailer I'm running at the moment which it is a normal Tamiya trailer.
I have never had any problems with my last trucks of towing this trailer sometimes it has A-trailer in front of it.
