Old 06-16-2014, 10:34 PM
avel avel is offline
Default Re: LR634 is HERE!!!!! Tracked loader
http://youtu.be/HFAJzpG8cpE
The Orings kinda worked, in that I had to cut down the OD to fit into the grooves. On the lift pistons one of the sealing edges was torn out too. So the Quad or X rings that I got didn't really work without modification. I might try some other sizes if I want to purchase a 100 of each size from Mcmaster. This order was from theoringstore.com which lets you buy them individually.
I used my Xuron flush cutters to trim down the outside of the Orings, and so far everything is sealing.
For screwing the hydraulic cylinders closed I used two pieces of bicycle inner tube. Just wrap it tight so its stretched and twist. Then I used some tube to cushion the jaws of pliers to tighten it down a little.
Youtube username iamaman27
