Old 12-23-2014, 08:35 PM
Snowman3725
Guest
Posts: n/a
Default Re: Tech help needed
Originally Posted by bigford View Post
where are you located?
Littleton MA. 45 mins out of Boston. Thanks David, I checked all the little things. It is brand spanking new so I dont even know. The servos work fine on the valves, I can hear them operating. The pump would turn on when you moved a the lever, and there was also a switch on the transmitter that would turn the pump on and keep it running. Everything else is good. There's a couple electrical boxes that flash a red LED light, don't know if that means anything.
