Thread: King Hauler 6x6
Old 02-17-2015, 08:44 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Default Re: King Hauler 6x6
Emil , i like your truck. Cool short wheelbase and tough looking.
if you determine that the cable tension is too high. The axels apart and investigate hoe they are made. I had similar issue and found that the manufacturer had springs inside and a torsion spring outside on the actuator. I remov ed the outer torsion and flipped my cable set up. ALSO Double CHECH The Gear Mesh On The Pinion And Ring gear. Mine stripped out way too easily.
