Old 04-27-2015, 06:37 AM
dozerbuilder dozerbuilder is offline
dozerbuilder is on a distinguished road
Default Re: Miniature plow-bolts for cutting edges/routers
Originally Posted by Stuart View Post
Are these what you mean? Dome head bolts
Thanks Stuart. On the right track, with a bit of work to look like tapered plow-bolts. Diameter at M2.5 is good = 40mm dia (1 3/4 ") in 1:1, excess length is easily ground off, and the head could be filed down and the bolt recessed into the 14-gauge (1.98mm) cutting edges. Or, recess them and file them off flush once in position. Thanks for the heads up. I was looking at some phillips head M3 PK tapered screws on the net, not sure how much of the head would be left once the screw drive slot was filed off though.
