Old 04-27-2015, 02:23 PM
pigeonfarmboy's Avatar
Default Re: a little dx9 help
Info above is good. Make sure you understand, the position your sticks/switches are set when binding are setting the fail safe. If you're throwing reverse when binding, it's going to go to that position when rf is lost.
Throttle cut should not need to be used, if that's reversed, that's likely causing your issue.
Check your monitor section to make sure there's nothing strange going on.
