Old 05-25-2015, 06:33 AM
Prop Shaft's Avatar
Default Re: Capo 1:8 Jeep CD15823
Originally Posted by Rakthi View Post
Hi Prop, looks like their quest for realistic scale has infringed on the suspension. Seems like you found a solution though. On the pictures I can not make out if the axle is of centre. Did the oil for the shocks come with the model or is that an extra purchase? Looking forward to your next update. Must say the parts look meticulously machined.
If you are going to use the Jeep a lot you might have to trim the steering from time to time due to cable stretch. I guess they have provided the means for that.
Trimming the rubber of the servo wires ... neatly done! I would probably have nicked the wires themselves trying to do that.
Stephan
Its hard to tell in the pic but the axle more to the right, and under compression it gets closer to being centered. No oil or grease is included. I threw in some 30wt. Yup there are adjusters for the cables. And the trimming the rubber wasnt bad trick is to use a nice sharp exacto and bend the grommet while making light cuts. If that makes any sense...
