Old 05-25-2015, 09:04 PM
Prop Shaft's Avatar
Default Re: Capo 1:8 Jeep CD15823
So heres where the real disappointment comes in. The steering seems to, well.... SUCK! I have dialed out all the slack, to the point where all i can do now is back off the adjusters, and rewrap the cables on the servo horn to tighten them back up.. There seems to be a lot of cable stretching. But with out even any real weight on the truck, the steering is struggling to center itself. Granted it might work fine while its moving, but I cant see it performing very well while crawling or under moderate bind situations. Take notice of the actual servo horn in this video. Its a 425 in/oz servo and is crazy strong. But the setup looses so much by the time it gets to the steering arm.
http://youtu.be/yo61bnruUCM
I smell a chassis mounted servo in this rigs future. Looks like theres plenty of room at this point. The motors sitting a little crooked but you get the idea.
Bit of a size comparison. I set it on top of my Capo 8x8, which is a huge, true 1:10 scale tatra.
Its actually a bit wider then the Tatra.
