Old 06-15-2015, 09:07 AM
JAMMER JAMMER is offline
Default Re: LilGiantsConstrCO
Well Joe you can't say you did not get any use out of it. If you are getting slop in the bushing you should put brass sleves in and you might get away with just reaming the holes for the sleves. I hope you don't have any trouble getting that broken rod end out just in case you forget heat that a little it probably has lock tight on it. Ed
