Old 07-03-2015, 01:50 AM
TylerDSAudi TylerDSAudi is offline
TylerDSAudi is on a distinguished road
Default Re: Progress Thread - 8750 Marion Dragline
Originally Posted by SonoranWraith View Post
You can still run the model with radio control but use shore power. You can use many different units to get AC to DC, like an old computer power supply or search ebay and there are a lot of choices. You could mount inside if you have room (there never is) or have the DC conversion on the shore side and run the line to the model. Wired works too just more cable.
see I was thinking of using a computer power supply cause that plugs into 110v and then you'll have to convert it to whatever voltage you need. I would like to mount the power supply and such in a box ( switch shack ) like a real drag and run a cable to the shovel! Maybe I convert a small backhoe to move cable around
