Old 08-16-2015, 02:47 PM
ozy operator ozy operator is offline
ozy operator is on a distinguished road
Default Re: motor speedy combo to weight ratio.
Originally Posted by rsd53 View Post
Rhys, spending $250 AUD seems like overkill to me, for an ESC and motor. A little more information would be helpful.
Are you planning on using the stock transmission? ESC's aren't too expensive. I replaced the stock motor in my KH with a 65T ($10). The higher the number of turns the more torque is produced. The catch is as torque increases, speed decreases. It sounds like you are looking for torque. In addition to a higher torque motor, you could install a gear reducer, that can double the torque, but also lowers the speed.
Rob
Thanks for your reply rob
Ok so I would like to stay with stock 3 speed if it will work and can always stay 1st gear for heavy hauling and have the 2 other gears for speed when needed..
The reason for asking as I have a hobbywing motor and speedy in the truck now as its all I had from a drift car now I need torque. If I need a gru I will get one.
even tho its expensive will this combo work can always play with pinion as well.
Cheers
Rhys
