Old 10-24-2015, 09:38 PM
modelman modelman is offline
Cooper-your tire plug looks good. Have you decided how you will mold it? After I made mine I figured out a way to make it in to equal halves by using one mold. Make the mold come to the exact centerline of the tire, then pour that part and let dry. Then remove it from the mold and pour the other half and drop the cured half on top while it is wet and the tire will be bonded together. You will need a "key" on the tire and mold to line up the 2nd. half but it should work. If you do it this way you will need a leveling table to have the mold exactly level when pouring. BE CAREFUL WITH THAT ACETONE!!!
