Old 11-05-2015, 12:49 PM
Digger_Bear Digger_Bear is offline
Digger_Bear is on a distinguished road
Default Re: Magom Brushless Pump
Hard to bleed the lines I found. What I did was have the excavator on the work bench then kept the bucket as low as possible over the edge. Idea the air flow to highest point which was the valve block and pump.
Not certain if air would go back through the oil like that but was only logic I could apply.
