Old 11-24-2015, 09:30 AM
Default Re: PC1800 Front Shovel (1/12)
Originally Posted by DADSGARAGE View Post
You might be right about the relief valve not liking the the low pressure, I wasn't thinking of that style of relief valve in there not a simple ball and spring, if it wants to float around at the low pressure I will need to add an external one on later to correct it....l will try it first and and see what it will do...maybe just maybe it will work with the low pressure.
Do you work on this machines or operate them??
I'm a technical trainer for a Komatsu distributor in Kentucky & Indiana. Mostly, I teach our technicians but sometimes do troubleshooting classes for customers. Our territory has shovels up to the PC5500 and trucks up to 240 tons, but with the coal market going to h3ll, many of the larger machines are being parked.
