Old 01-04-2016, 08:55 PM
Cooper's Avatar
Cooper Cooper is offline
Was thinking around 5/16. If I went the broaching way I would make the female part out of steel not alum. That would be the wheel hub cap. 1 , I don't have 2.5" steel stock, 2, not my favorite material to work with using small size drills/mills. (If I used the rotary table ).
I don't think a steel hex shaft would last too long in a aluminum socket, do you guys? Referring to the aluminum wearing quick, developing slop. What's your guys opinion on making the female hex socket in alum? My thoughts are on this small size 5/16 or 1/4" it wouldn't last. Or would a square hole be better? That is if I don't just go with set screws and a flat spot.
