Old 01-27-2016, 11:13 PM
Default Re: Servo help needed
Yes you can. 2pos is Gear & one side of the switch is either +100 or -100, giving you full throw of the servo. If you want to shorten the throw on either side, lessen EPA for that side.
Then to use left stick sideways (Rudder on mode 2), enter into Mix 1, Rubber -> Gear, then get your + - in the correct order to make it work.
