Old 12-22-2010, 04:00 AM
Katan Katan is offline
Katan is on a distinguished road
Default Re: What would be the perfect powered front axle.
Originally Posted by ihbuilder View Post
as long as the ratio is the same a stock tam . Now I'm gona get you thinking , come up with a dual output for the rear that mates with them . with no mounting
IHSteve
The axle has the same ratio as stock but you can put a Tamiya diff into it.
The axle was actually designed as a High Lift upgrade so it is fully Tamiya compatible, diff, leaf mount spacing, knuckles, stub axles etc...
The stock Tamiya dual rear output will mate with them as they use the same diffs so no need to make another one.
I already did a rear axle casing with the diff properly centred with a more scale appearance. It is a direct replacement for the stock rear axle, just put you own diff into it:
http://store.rc4wd.com/CNC-Straight-...emi_p_928.html
Originally Posted by fhhhstix View Post
That looks good Katan with the thinner hubs it would bee the same width as the stock steer axle. You said it has a spool in it but would the diff out of a tlt or semi fit in it if a builder wanted the front to not be so tight. Next how is the steering angle compared to the tlt axle more steering would be a plus. Would a builder be able to put a rim on it with more offset.
Travis
To be honest I dont think the thinner hexes are needed as it's only about 1mm wider. Tamiya diff + pinion shaft are a direct fit. Steering is better than a TLT. Any rim can fit on this axle but more offset means the wheels will stick out more.
