Old 02-11-2016, 10:38 PM
mcl fabrication mcl fabrication is offline
mcl fabrication is on a distinguished road
Default Re: Which radio is the best for Tamiya 1/14 trucks?
Cant tell you which product is the best but I can tell you what I would do if I was doing that build. To keep the build simple I would use a 4 channel two stick radio (programmable not necessary). Use the leg support channel via E.S.C to motor that turns the mixer. For continuous rotation of either direction adjusting the trim lever for that channel. I'm using this set-up now on my dump trailer. It will work on a mixer build. Ball bearing servo's are not necessary but good to have. There is a video on YouTube on a Bruder mixer conversion it was the coolest thing to see. Any how good luck on your build.
