Re: Which radio is the best for Tamiya 1/14 trucks?
Cant tell you which product is the best but I can tell you what I would do if I was doing that build. To keep the build simple I would use a 4 channel two stick radio.
Use the leg support channel via E.S.C to motor that turns the mixer.
It will work on a mixer build. Ball bearing servo's are not necessary but good to have.
