Old 03-12-2016, 08:24 PM
Default Re: setting up transmission positions
First unhook the shift linkage from the servo. now for whatever channel you are using make sure it is in the middle position now adjust the servo horn as close as you can get it to where you can put the linkage on without moving it in or out on the trans then you can adjust the trim so you can get it to fit perfect without moving the rod. Then move the channel to full direction one way or the other. Then adjust the end point to where the e clip is just about to touch the Trans. Then move the cannel to full direction the other way then adjust that end point so the e clip is just about to touch the case.
That is as simple as it gets. If you do not understand that you may want to go on line and find a radio manual and learn the terms and definitions of the radio and functions.
