Old 03-22-2016, 05:25 PM
Default Re: Tamiya Reinforced Output Shaft?
HAH! that's funny Emil ...and true! The only failed part I have ever had in a stock tranny is the top middle aluminum gear for 2nd in the white GL that has a million scale miles in over a decade of run time.
That "HD output shaft" is about as necessary & useful as the brass helical gears... sucker's play.
The radical amount of wear on that above trans is probably less about lube & more about what that in runner brushless motor's top speed is set to?
That is exactly what I was thinking!!!!!!!!!
