Old 04-07-2016, 11:16 AM
Rimrock Rimrock is offline
Default Re: hyd pump question
The Magompump you refer to would fit alright in a 320 in 1:14-1:16 scale, but if we're talking about scale 1:10, I would look for something bigger. A 320 in 1:10 will be like 20 kgs weight, similar size as the RC4WD XL4200. Pump 600-900 ml/min is a typical preferred size. Magom has got much fine stuff, but to be honest, their pumps generally seams to have some way to go still..But for low budget builds, one can possible live a while with some more or less 'flaws'. The one you refer to is a version without the motor. There is another one complete with the motor. Big noice. (Not always 18 bar 'out of the box', my friend's pump delivered max 10 bar, but he got 18 out of it after opening the pump and did some 'sanding' inside) Cylinders are ok. Small valve blocks; often leakage. Biggest valve block, possible better. The german Leimbach hydraulics is of higher quality, and would have better options than the Magom you refer to. But for 600-900 ml/min pump, it better go for the good stuff at once, Premacon or Fumotech of Germany. Relative expensive compared to Magom naturally, but one will save oneself for a lot of frustration by from day 1 putting in some hydraulics that really are able to work, day after day, without bigger problems. Hydraulic fittings, M5, for hoses Ø4x2.5 will be what you should look for. The hydraulics and electronics are the most expensive parts of a RC excavator, and since this is your first RC construction machine scratch build (?) I would suggest get going on the excavator structure at first, and wait until nearly finish with that step, then purchase the expensive stuff in the end
