Old 05-23-2016, 04:40 AM
Rimrock Rimrock is offline
Default Re: RC4WD 4200XL models and nomenclature?
Originally Posted by alaskantoy View Post
I just received an email stating I received the "updated" valve hydro block. still having issues with slow movement, and the hydro lines loosening up and causing leaks and sucking in air.
Slow movement is likely due to air in the system. Too low oil level in the tank. I don't have a quick, good 'non messy' way of emptying the system for air, but maybe others have? Theoretically the air should come out by running all cylinders in and out enough times, having the tank filled up to proper level at first.
Adding thread locker to the nipples will not hurt. E.g Locktite 542
