Old 06-12-2016, 05:31 PM
Default Re: Metso Lokotrack LT120, Jaw Crusher.
Originally Posted by 9W Monighan View Post
Any more progress on this outstanding build?
Not really, I have done a test run, but I forgot that I just had spot welded the fixed crush plate so it came loose and that was the end of that test!
I did re-weld it the other day though, so now it shouldn't break loose.
One more thing I have noticed is that the crush plates should go into each other if you would lay them together, as the sit in the crusher now, the tops of the pattern lines up with each other, guess it would crush better the other way.
That's about it, it's summer now and I don't spend much time in this hobby this time of the year, more of a "get through the winter" kinda hobby.
