Old 07-31-2016, 12:34 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default Re: 1/16 Oliver Dozer Conversion
I'd go with a separate BEC so when you are under load or possibly even stall the motors you don't have issues. If you run a separate BEC, you would not use the power wires from your esc to the receiver. Also I note that your diagram had a flip channel which is mostly used for bots. It can be used to drive in reverse easily but can just as easily be left unused. Cheers.
