Old 10-29-2016, 04:01 PM
oldguy70 oldguy70 is offline
oldguy70 is on a distinguished road
Default Re: Need help with fittings please.
Crusher
I always use Festo fittings the small series have 4 and 6MM lines the fitting has one end threaded 5mm (I use a 8-32 tape, and 1/8 NPT, the other end is a push in for the tube. Elbows come with a swivel so you can place them beside each other, rated 150PSI but these smaller sizes will take 300PSI as that's what I run my models.
Earl
