Old 10-31-2016, 08:00 AM
Papy Papy is offline
Default Re: New Eagle Mach Excavator 1/14
Originally Posted by trewq View Post
I like your review!
Oh, I nearly forgot to address the weight issue.
I know that it is very hard to pull a loaded trailer. 27kg, I bet the trailer has at least 3 to 5 more and that makes really heavy load. I don't fancy trying to tow that on a loose surface. But, isn't that what is fun? Building your tractor truck with large reduction rates, having decent amount of power, building and "cheating" the drivetrain to make it - yeah, that sounds fun to me!
Thank you all for the kind comments!
For the weight on a trailer, I can confirm this is absolutely not an issue if you have a "beast" under the gooseneck......but do not consider tuning only the powertrain will do the trick : standard Tam suspensions will just be crushed
I strongly recommand installing a pair of Reg's excellent walking beams
