Old 01-07-2017, 07:06 PM
roadranger's Avatar
roadranger roadranger is offline
White Line Fever
roadranger is on a distinguished road
Default Re: First Tamiya truck build, MACK Dump truck 6x6
Understand! Was wondering if the cab and fender/hood assy. were for sale somewhere and then I found them at Shapeways. Is this cab the one with the non opening doors?
Looking forward to this build, as I might have to change plans on my 6x6 tractor build from a Globe to a R model. Spent a lot of years/miles in R models.
I hear that sanding these printed bodies down smooth for paint is a bear...
I'm using the F350 powered steer axle with F350 springs with factory holes drilled in them, and it does lift the front end up some. But so are the 1:1 6x6 trucks. I've seen some guys redrill the rear suspension mount holes lower down to get the frame to ride level. OK for a straight truck, but a tractor will be too tall to hitch up to stock trailers anymore, just like the 1:1. You just put blocks under the landing gear legs.
WILDCAT T&C
Jim B.
Colorado Springs
