Old 01-09-2017, 11:17 AM
Bo Wallen's Avatar
Default Re: Topcad replacement front axles
Originally Posted by SteveDownSouth View Post
No, you're exactly right, it was the front axle I have a real problem with. It's so unbelievably sloppy. I need a solution so I can fix it, but I'm pretty new to this. Thanks
All my trucks are that way....from start. Here is a few mods to do.
1. the rod ends from servo and the parallel rod between the hubs need to be. http://store.rc4wd.com/M3-Offset-Sho..._p_1741.htmlOr better.
The play in the axle assembly does not matter at all when you drive the truck.
It just feel bad when you put it together.....(i hate play in joints too)
Next is to increase the Caster angle a bit. that make the truck to want travel straight. This is the extreme way to do that ;o)[IMG]DSC_2299 by Bo Wallen, on Flickr[/IMG]
