Old 03-04-2017, 11:34 AM
Stuart's Avatar
Stuart Stuart is offline
Default Re: Joskin KTP27/65 Tridem
Lots of hi-tech on this trl build Stuart it's gonna be wondrous to see it in motion
Thanks Joe, gone a bit adventurous on this one!
Originally Posted by Grainfarmer View Post
Great job! How did you get the air bubbles out of the suspension system?
Thanks Frank,
I connected the 3 cyls with the hoses then turned them upside down without the pistons fitted.
Filled no.1 with oil and put the piston in, pushed gently until oil appeared in the bottom of no.2, filled no.2 with oil and fitted the piston but pushed it all the way in then did no.3.
That way when 1 cyl is fully closed the other 2 are fully extended, et voila!
It works a treat, there a little on the tight side, may need to take a tad out the piston groove to loosen it but I'll try it loaded first.
I worked out that with a 15Kg load the pressure in the cyls is around 9 bar, should be ok, I hope!
Having trouble with the steering geometry at the moment, I've got too much travel at the axle end and it reaches full lock too soon so need to tweak the angles a bit, will update once done.
Stu
