Old 03-29-2017, 10:37 PM
Default Re: Eagle Mach JD-98/RC4WD DXR2
Originally Posted by Efroeh View Post
I watched your video and it seemed you were doing a good job running that rig. How do you find the build quality and would you recommend it to someone else?
For sure. The only issue I've come across mechanically are the planetary's and they still work just not sure for how long. This also seems to be only with my machine, haven't found anyone with the same issue. There are some annoying design features, mainly the access to the fluid tank in which you have to remove the tracks, cab, and fight with the sprockets to get to some tiny hex screws under the fenders to remove the cover over the fluid tank. Still once you've done a couple times it's not too bad. Overall a decently detailed machine that'll move some real dirt and looks frick'n awesome doing it!
