06-05-2017, 03:07 AM
Re: Scaleart axle problems?
Thank you for your answer,
Originally Posted by Rakthi
Nope, not have had any problems. Are wheels and axles from scalart?
Yes, both wheels and axles are Scaleart.
Front or rear, if front driven axle or not?
Rear axle, the one without throughput
What exactly is the problem?
When I first attached the axles to the chassi and checked that they both turn the right way, I couldn't turn the rear axles with cardans in place. Took the cardans off, and all other axles was OK, but not the second rear one, it was stuck. Took it off, and turn it by hand and it loosed up, but it still have a noise that something is not OK. I have contacted Scaleart but they have not answered yet.
Are your axles the new version or the old one? (new ones you bolt the wheels to the axle, the older version has the bolts already in place and wheel bolted on with a nut.)
There is special piece to what you bolt the wheels, then you put the hole thing to the axle, it didn't fit either but got that to work with a drill and some sandpaper.
Can you post a picture?
Yes I could, but the problem that is left is not getting any clearer with a picture
Stephan
