Old 09-27-2017, 11:36 PM
Default Re: Liebherr LR634 Track Loader HYDRAULICS
I'd go with the Leimbach hyd system, much more compact than the Premacon kit with Jung pump & Meinhart valves. For only two functions, you'll get plenty of flow & power from Leimbach too with 2mm plumbing. Plus with an esc on the pump motor, start/stop on Leimbach's small brushed motor is possible; whereas the Premacon kit would have to be in constant motion to prevent esc freeze.
