Old 01-19-2018, 03:05 AM
Quick tip with Chinesieum escs that have no instructions:
First figure out what type connectors it has installed. Find out what the connector standard is for battery, so if battery has a female then the esc hookup is male. The esc output to motor should be same as on a battery to follow power flow.
So on my cheap 20a if i want to run a deans on all my battery, i can cut the female jst and some wire off the esc, solder on a deans male, then the off-cut Female wires can slap onto the motor and it's now really easy to swap if stuff goes bad.
