Old 01-19-2018, 06:57 AM
Default Re: Air compressor trouble video
Sounds like maybe either the unloader/blow-off valve spring is weak, making it want to dump early? or the pressure switch is sticking so it doesn't cut out normally and has to vent?
I didn't see a gauge, but you sounded like it is struggling to get up to shop pressure somewhere 90-120 psi?
See if the valve up top has a screw adjuster somewhere to change the preload where it dumps? Or the pressure switch should have one or two to set motor kick in / kick out
