Old 08-10-2018, 08:22 PM
Default Re: my 870 rc4wd loader
Sounds like you need to lower the psi thru the pressure relief valve. It might be set too high causing hoses to pop off?
I'm surprised you had to go thru all that trouble. I also bought mine the same time as you and havent had any issues. I did however lower my pressure relief valve and the speed of the pump. I only did that just to feel more scale in power and speed.
