Old 12-09-2018, 03:15 AM
Default Re: CAT 14M3 Motor Grader
Originally Posted by Tunnelmaynia View Post
Hello hemi1966,
I am very impressed with your work. I am a fellow machinist and I also use fusion 360 for my CAD and CAM. I want to start a build of my own but the biggest obstacle finding scale drawings or even the 1:1 size to be able to scale down. Can you please share where you are getting your dimensions from. Also some photos of your machines and maybe some work holding. I really like the idea of building them yourself versus buying a manufactured version. Thank you in advance for the help with the drawing sources. Jeremy.
The big difficulty when making these is the lack of scale drawings
I first get a 1:50 scale die cast model of the object, with that you can get some measurement.
The machine brochure usually have some dimension drawings.
One place to look is also this: https://avspare.com/, there you can get some idea of the parts.
Drawing a part that is more complex often takes more time than actual machining. The following parts assembly I was drawing many, many, hours
Click my signature at the end of this message to get to my Youtube channel to see some machining videos.
