Old 04-19-2020, 12:26 PM
Default Re: last thing left i hope
No manual bleeding required, cycling cyl in & out removes all the air. If hyds are spongy, your oil tank is low on oil.
Slow cyl movement in one direction but not the other, servo on valve needs EPA adjustment or servo is junk & not giving full rotation in both directions... stop buying chinese made electronics, they're cheap for a reason -> there life expectancy is short. Use quality servos like Hi-Tec or Multiplex.
