Old 04-20-2020, 12:40 PM
Default Re: HIAB X-HIPRO 1058 loader crane
Originally Posted by Trucker47 View Post
Hey Hemi,
Build is top quality as usual! I assume you are using a TIG to weld? If so what thickness is the steel and how many amps are you running?I just picked up a TIG and have lots to learn!
I use 2 mm steel on the column and the first boom. The first three telescopes are 1 mm and the rest I will made of 0,5 mm steel.
The Tig welder I have is this one, but an older modell :
https://www.schweisstechnik-lampert....el-making/m280
It does not show the actual amps, just a percent value, so no idea
