Old 04-21-2011, 09:54 PM
Default Re: Hydraulic Pump Motor Control Options
Originally Posted by SmallHaul View Post
I think it might be better for the pump if it is running slowly when it goes to full power than to just turn all all the time from a dead stop.
Full sized equipment recommend full rpm for full pump out put as to not starve the hyd components and also not to over demand the pump. I would think the same hyd principles would apply to our stuff as well and if it is a heat issue you are concerned about a hyd cooler is a cheaper and more effective solution.
Travis
