Old 04-28-2011, 01:52 PM
SmallHaul's Avatar
Default Re: Leimbach pump tip
Great info Rob!
I am working on a Wedico loader now that has a leimbach pump and a fluid soaked motor. I flushed the motor out with non-flamable CRC cleaner and that worked great but, after running it for an hour I could tell that a small amount of oil got into the motor again.
So, I will flip the motor over so that the oil can drain without going into the motor but, can I change the seals so that won't leak any more or won't that help?
Scott
"No load is too Small"
