Old 05-15-2011, 08:00 PM
Default Re: Barge-Mounted Clamshell Crane
Originally Posted by Jared View Post
You might have to build one of those bags or buckets that helicopters use to drop water on fires. Left stick is u/d for boom, l/r for swing, right stick is u/d for the holding line, l/r for the closing line. To hoist a full bucket the right stick goes to the bottom left. If it was a dragline I would have the drag drum be u/d on the left stick and boom as l/r on the right stick.
Your set up is similar to mine and Smallhauls set up. I have to leave my boom fixed at one angle. Scott has the throttle stick for his boom angle but it's turned on with one of the switches that I found out by accident when I boomed up into the cab I didn't see it happening because some guy was talking to me and I wasn't watching the boom.
Here's mine hope the dashes don't confuse you.I don't know how to put the diagram with out the letters bunching together.
LEFT STICK--------------------------------RIGHT STICK
--- not used-----------------------------------hoist up
swing left-----swing right------------------- drag in------drag out
------- not used ---------------------------------- hoist down
