Originally Posted by rockNmayhem
The servo is only drilled through just behind the pot on it where the casing is hollow. I chose it directly center of the ram and just behind there for the best center pivot point to the actual ram. There is no modification other than what I have done for full rotation to the electronics. I will be using a piece of brass tubing running through with a wrist pin to pivot on like a normal cylinder would so everything will be encased. The screws are just temporary holders and work great.
Thanks
I'll have to make note of that modification to be able to use it on some upcoming projects.
The excavator is really coming along and looking good doing it
Jordy
