Old 05-30-2011, 08:14 AM
SmallHaul's Avatar
Making great use of my newly aquired Spektrum radio system, I added a Spektrum rx to my adt & took advantage of the "two mixes" feature of the tx to combine the hydraulic pump with the two hyd valve controls of the steering & dump.
Very simple to calibrate, got it on the 1st try without even reading the instruction manual... very unusual for me!
This little trick should increase batt run time maybe as much two fold or more.
Isn't the Spektrum/JR programming structure great. That is cool how you have the radio setup Joe. Will you add the esc pump control to your front end loader and excavator?
Scott
"No load is too Small"
Last edited by SmallHaul; 05-30-2011 at 09:40 AM. Reason: Spektrum & JR programming structure are similiar
