Old 11-11-2011, 02:54 AM
justinart24's Avatar
justinart24 justinart24 is offline
justinart24 is on a distinguished road
Default Re: Justin's "Ford F-350 Flatbed" Crawling Hauler...
The body is sitting a bit high, will try to be lowering it about .5".
I will be using RC4WD seats.
Not sure if I will be running the Tamiya Semi gas tanks but they look pretty cool.
Make some leaf spring mounts out of steel, seems to do the job.
Rear axle, might be adding two more helper springs....my scalers are pretty heavy.
I also might be doing a sway bar setup on the rear axle, need to test drive it first before I do that.
Close up shot of the sick RC4WD double trouble wheels.
Rear wheels.
My Builds
