Old 12-06-2011, 05:43 PM
Default Re: PFB Tri-Axle King Hauler
Looking good Nate.
The 850 will certainly be the ultimate for a durability test on Russ's suspension components!
Tri drives... wide turning radius, if it turns at all! You americans don't use jeeps?
Jeeps are for mud boogin Joe , A co . down hear moves a 385 cat with a triaxle tractor and a 5 axle trailer .
looks good Nate . you might want to center the 5th wheel over the 2nd rear or make a sliding fith wheel . If your building your own trailer make the neck long .
(edit) here you go http://www.trailking.com/trailers/?trailer_id=45
