Old 02-19-2012, 04:52 PM
Default Re: Espeefan's slow motion Peterbilt Heavy Hauler build
I don't machine like some of the other guys here you only see the good part not the hrs of fustration , for instance , you spend hrs manually doing 1 op on the lathe only to get screwed up in secounds on the mill I realized friday that the coaxial indicator I got is total crap same with the digital caliper after a few hubs (days worth of lathe work ) bearing bores where off . now I'm going to make a different setup jig much like a pallet system .
A/C I'll try to run them this week with rc channel hubs I have to run ( same stock )
